keyboard / mouse or motherboard problem ?
15 Apr 2013
hi.
most times when i start up my pc, my keyboard (mostly) and mouse (less often) does not work. when i unplug them from the pc and replug them in after
they work fine.
my mouse is a good few years old, keyboard is a bit younger, and the motherboard is the newest
Keyboard: Razer Deathstalker
Mouse: Razer Ouroboros
Motherboard: Sabertooth 990FX
im unsure if its the motherboard is faulty ? I didn't have the problem from the start
or if its the keyboard and mouse on the way out
any help is very welcome
Usb port devices? Are you using usb connections in front or rear? If using front, check leads connecting to mobo. Also try swapping devices from front to back ( direcly into mobo )
Firmware update
what revision of bios have you got?
ah yes,
its in the USB port at the back
on the asus update form AI suite II it says
Current bios
Sabertooth 990FX R2.0
version 2104
i had a problem with 2 Logitech G500's
Common problem is the point where cable goes into the mouse
i've opened it up and shifted it inwards, now its nice and tight and problem went away
What revision of bios have you got? Might be worth flashing.
Are you ussing Usb 2 or 3 ports? Try swapping from 3 to 2 if you're.
Youve only got 2 usb ports in the back??? Surely not. Can you specify exactly which motherboard you've got? Make sure your devices are plugged into USB 2 rather than USB 3
ah i get hat you mean.
i got 2 in use.
i got 6 2.0 ports
and looks like 4 3.0 ports
keyboard and mouse is plugged into 2.0 ports
So your devices are plugged into Usb 2 ports. Have they always been plugged into these ports? Have you tried swapping ports?
Have you got any spare Usb devices you could trouble shoot with? Possibly borrow a friends? If that fails, if youre looking to upgrade your mouse/keyboard anyways, might be worth purchasing new products. Atleast that would rule out of its a bad connection in mouse/keyboard or actual motherboard.
Obviously make sure all drivers are updated and installed.
yea, always plugged into usb 2 ports, i have just changed it to different usb ports, i might try them on my wife's pc, if same problem comes up,
