When booting into Windows, my keyboard does not work straight away. This appears to be an issue that comes and goes, but most recently it has happened every time.
It is not the keyboard, I've tried another.
This keyboard appears to light up as I press buttons while its not working, as if it is getting power only when a button is pressed.
It takes about 15-20 seconds at the login screen before the keyboard starts working.
This issue has only existed since upgrading to this SB rig, and the problem has been present over two windows installed on the same rig.
The keyboard is connected to the built in USB hub on my Dell 2408, the same as the mouse is, however the mouse works straight away.
This issue is specific to windows login screen - the keyboard works fine in the bios.
I think that is all the information I have, someone else must have experienced it?
