keyboard problem...
25 Nov 2004
i have a basic logitech black keyboard...and when ever i'm playing games and i hold foward arrowe(fowards arrowe) and then try to crouch(ctrl) or reload(kps) it doesn't register i have to let go of the foward key it hasn't always done this only recently any ideas? :S
Are you sure that you are only pressing a maximum of two keys at a time? Even the cheapest keyboards I have ever seen are capable of coping with three simultaneous button presses. Your keyboard shouldn't need drivers but if you have updated them(is that possible?) then I'd suggest reverting or alternatively if there are drivers that you haven't installed try installing them.
It is a very odd problem, sorry I can't help more.
i try using that keygen thing...and it's when i hold the foward arrowe neither key left or right can be pressed at the same time...
foward > ctrl
foward > kps
