Keyboards - Key Spacing
18 Jan 2009
Co.Durham
Hey All,
Hope everyone has had a good week :)
I'm looking for some advice assistance in regards to keyboards. Last year I picked up a Razer Blackwidow Chroma v2, there's nothing wrong with the keyboard itself and I quite like the yellow key switches which Razer used in this version... the one problem I do have however is the key size/spacing, at first I thought it would just be something that I would find myself getting used to but now a year on I still seem to continuously encounter issues while typing due to the key size/spacing on the keyboard.
I don't have any problems using the standard Microsoft keyboards fitted to our computers at work and they feel "normal" to type on, but my Razer drives me mad and is a pain to use if I'm totally honest. I'm considering swapping out the keycaps or possibly the entire keyboard to something with a more normal/standard key size/spacing layout.
Would anyone be able to recommend a good alternative set of caps or an alternative mechanical keyboard that doesn't suffer from the smaller key size/spacing that is present with the Razer?
Thanks,
I also found the keys on the Razer to be too far apart and like you caused me many a frustrating moment, by comparison I found the Logitech Mechanical Keyboards to be much much better to type on (I've tried the G910 Spectrum & the G513 Carbon), also I find the Ducky keyboards to be great as well :)
