Bit of an odd issue developed with my keyless entry on the focus.
In the last couple of days none of the door sensors will lock or unlock the car - but oddly the boot will still open without being unlocked first.
I initially thought it was potentially just the sensors playing up in the cold but it's too consistent an issue to be that now.
Pretty much ruled out individual sensors as all four doors worked fine, now none do. All fuses that I can see relating to the system are fine. Don't think any of the relays do much for it.
Scanned with forscan (on my phone, will check using a laptop too) and can't find any error codes relating to the keyless system at all. Expected to find some sort of communication error or an outright fault with the bcm or similar.
Also sure it isn't the batteries in the keys as neither work on the doors but both open the boot. Car locks/unlocks fine with the fob
Only things left that I can think of are the battery nearing the end of its life or an antenna issue (but again would expect a code). Will stick a voltmeter over battery at the weekend but I'd expect to find more issues than just keyless funnyness if this was my issue.
I'm otherwise pretty much stumped and it'll need to go to ford - any other ideas first?
