Malwarebytes?
If not then nuke it.
How do you know you have one?
Cause I can't get into Safe Mode without a password and things I type are been relayed back to over my speakers on occasion. I spent a while already recovering other network hijacks already. I think he's using Bluetooth to log with it.
MB didn't touch it.
.Is this a friend prank or do you have a job worth logging your system? If you think it's Bluetooth either kill the Bluetooth device and see if it stops or find where they're logging it from its only a 60ft range iirc.
Hi.
I have a keylogger on my system. Any ideas how to remove it ?
Inside most buildings it would be more like half that. I've managed ~60 foot in the warehouse at work but in the office part it doesn't go more than 2-3 rooms away or so.
BIOS passworded too so I'll just live with it till I can do a full reinstall. Thanks anyway.
