The coolers do the job on there now but I'm pretty much temp limited now In benches with the top one hitting 91c . Voltage seems to annihilate all my remaining headroom . There being thrashed to get to 91c admittedly. Is there anything other than going for a full loop to get temps down ... I'm trying to design a 120mm fan bracket that sits between the GPU's held by the holes left from the sideplates . But we will see how that comes ... Are there any AIO options for this card ?
gives you the option to mount four 120mm fans. Two vertical and another two over the top of the cards.
