Kfa2 2070 super temps?
30 Nov 2014
Thatcham in Berkshire.
Anyone got this card? Can't find any reviews anywhere. Just bought it (the 2 fan one) and wondering what average temps are. Hoping I made the right choice as there was a palit card for a similar price
Had a galax card before and loved it. (hence why I went for this)
How is it? Temps ok?
So far they are great. they were around 63 with stock clocks even when it was hot today, with a 150mhz overclock I am only at 72c at 100 card usage.
So very happy. comparing that to my broken Zotac 2080 I sent back (before I got this) that was reaching 85 at times at stock temps, and this is getting better benchmarks.
Fantastic, thank you. Right on the edge of buying one but not much info about it online!
I only pulled trigger because I had a galax (same brand just in different region) 970 years ago and it was fantastic. overclocked hugely and was really cool (temp wise and looks wise)
I personally think the rgb on this looks a bit tacky, but its facing down so dont see it., lol. its a heavy beast though. I use a gpu brace.
Only bad thing about this brand seems to be the low warranty compared to others, but so far this seems solid and a decent overclocker.
lol fair enough. I just got a p600s, but considering getting thr metal side for it as terrified the glass will smash (I have 3 kids)
I have one (kid, that is!) And I sort of came to the conclusion that they are drawn to bright flashy things... So a bright flashy box will be sure to get unwanted attention! The big black R5 box on the other hand seems to go largely ignored
I pulled the trigger late last night and bought one of these to replace my 970 as it wasn't cutting it in VR.
I was playing no man's sky last night and a bit of elite dangerous. Was fantastic. (on a rift s)
As I said on a different thread it's supposed to be at 1815mhz with gpu boost. But was at 1920mhz out of the box weirdly (not complaining at all) I have it at 2020mhz without touching voltage now at all. It's getting a lot higher benchmarks than my 1080ti did before at lower temps.
Super happy with it.
