KFA2 2070 super wb question
23 Apr 2010
West Sussex
I have the card in the title. Is the PCB stock? If not which block would fit?
It's the dual fan model that's £420 or so.
TIA.
Yup, nothing. The card is not on their site, only the triple fan version.
I don't like EK any way, I'd more want heatkilller or water cool.
Edit. I don't think it's stock. Rats.
They only show the 3 fan gamer card, and basically say they're never making anything for it. Which is part of the reason why I don't like EK. They're like the McDonalds of water cooling :D
If you look there you can see two rows of caps. This is the stock Super board apparently (according to a search engine at least)
So aye, ain't stock.
Oh well. I guess I will be sticking to the Titan XP then and will leave the 2070s on air in the other PC.
Yup fo sho ain't stock. I guess they used cheaper caps to make it the cheapest out there. Which is probably why no blocks will fit it.
It's not that it's too hot or I am disappointed, I just wanted to use it on my water cooled rig. It's slightly faster than the XP (not that you'd ever notice that though) but has the RT. I can't run a air cooled card in that rig due to the way it's been built around water cooling.
TYVM, but sadly that is for the 3 fan version "gamer".
I'll keep an eye on that site though, because I got a really nice Byski TR block for £35 inc recently ! I also have a feeling that if any one will do one it will be them, as they've made some for some really oddball cards.
Look at the first photo, it lists the compatible cards, the 2070 Super is listed?
Edit: photo 2 seems to show the larger 3 fan models :(
Email kfa2, I did about the 2080S and they replied in a coupled of days.
Heatkiller have a good look up table for GPUs.
