Hi all,
I have been getting occassional screen artifacts and corruption for a while and the most recent event, ac ouple of days ago, came hand in hand with a complete system freeze that required a hard reset. I took the pic below and as you can see it isn't a huge area effected. I have had worse but this is the first time I had to reset the system.
I have had the 'nvidia driver kernal has stopped responding' problem ever since I installed this card but previous research led me to believe that was a common issue with recent drivers and 4XX cards. This usually occurs when first booting into windows and then the system is fine until next reboot but it doesn't always occur.
I have had occassional issues in games and I have never managed to get completely smooth framerate in Black Ops, New Vegas or BFBC2 regardless of detail settings at 1680x1050, which has annoyed me.
My problem is trying to troubleshoot the exact problem as it isn't consistent. I have tried running the Heaven banchmark and Furmark but these never show any artifacts.
Is OCCT a reliable test routine, as a google search resulted in mixed opinions? I did run it and it showed significant errors, 8735 over 378.1 seconds
with a constantly changing pattern of white dots. However, the memory test passed 10 runs wothout issue.
Any advice from the many gurus here would be gratefully received.
