kfa2 670 ex oc problem
23 Mar 2014
Hi there i recently decided to upgrade my pc from a 650gtx to a 670 gtx and when i insert the 670 plug in the 6 pin power connector into the card and use the molex to 8 pin connector and plug that into the card then power up im getting one long beep followed by two short beeps then the beeps continue in a loop. The card seems to be powered up as the lights are on and the fans are spinning im using a MEDION AKOYA P2306 with 8 gb of corsair vengance lp
Hello and welcome to forum :)
Couple of options to try is see if the motherboard is running the latest BIOS and also do you know the psu manufacture and wattage.
hi there its just the stock computer that came with the gtx650 the gtx 650 works fine the 670 is brand new not sure about the bios but the power supply is fsp 450w
That link doesnt work btw
GENERAL SPECIFICATIONS:
COOLING Fan(s): Single, 80mm sleeve-bearing fan linked with Thermal Sensor
TOTAL OUTPUT POWER: 450-WATT TOTAL CONTINUOUS OUTPUT @ 50°C
OUTPUT CONNECTORS: Main 24-Pin, (1) P4 | EPS 4+4-Pin, (1) PCI-E 8 (6+2)-Pin, (1) PCI-E 6-Pin
(3) Molex 4-Pin, (3) Serial-ATA 15-Pin, (1) FDD 4-Pin,
NVIDIA SLI SUPPORT N/A
AMD/ATI CROSSFIRE SUPPORT: N/A
80PLUS CERTIFIED: YES
MODULAR CABLE: N/A
SAFETY APPROVAL: UL, cUL, TUV, CB, CE, FCC
MBTF: 100,000 HOURS @ TYPICAL
UNIT DIMENSIONS: 125.0mm (W) X 100.0mm (D) X 63.5mm (H)
4.92" (W) X 3.94" (D) X 2.50" (H)
UNIT WEIGHT: 2.31 LBS
RETAIL PACKAGE: 7.68" (W) X 2.91" (D) X 7.68" (H) @ 3 LBS
INPUT SPECIFICATIONS:
Input Voltage: 115V AC to 230V AC, 47 ~ 63Hz
Power Factor Correction (PFC): ACTIVE PFC | FULL RANGE
Input Current: < 5.5 A @ 115 Vrms, 60 Hz.
< 3.0 A @ 230 Vrms, 50 Hz.
Input Protection: Patented Input Fuse Protection
OUTPUT SPECIFICATIONS:
+12V RAILS: 2
Output Voltage: +3.3V DC
+5V DC
+12V1 DC
+12V2 DC
-12V DC
+5Vsb DC (Standby)
Output Current: 21.0A @ +3.3V DC
22.0A @ +5V DC
18.0A @ +12V1 DC
18.0A @ +12V2 DC
0.5A @ -12V DC
2.5A @ +5Vsb DC Standby
Output Protection: Complete OVP, OCP, SCP Protection
OVP: OVER VOLTAGE PROTECTION
OCP: OVER CURRENT PROTECTION
SCP: SHORT-CIRCUIT PROTECT
FSP450-60EMDN-POWER-SUPPLY-FSP-Group-450-Watt(from your broken link info)
i think thats your powersupply ,, dont link to other selling sites btw
The model you have shown is the right psu but the specs are not the same they there is no 8 pin pci express socket on my psu and the dimensions are larger on mine
