kfa2 760 temperature
29 Jan 2013
Hello everyone! Are there any kfa2 760 owners around? If yes then could u please share what temps does your card reaches when gaming?
The 760OC one? 27 idle and around 50 when gaming. That's overclocked over and above the factory OC to +100 on core and + 300 on memory. I'll update my post when I've tested it properly later. It's a pretty quiet card. Room temp is 23-25.
Edit temps below ...
Room - 22c
Idle - 26c
Black Ops II - 57c
Valley - 67c
In a HAF932 case. Custom fan profile to keep it under 70 degrees at load (fans are quiet on these). O/c to 1221Mhz Core and 3305MHz Mem. I've also changed the thermal grease but that only made a few degrees difference.
Fan profile ..
Im asking because I got one aswell and it reaches 80 degrees when playing guild wars 2... Sometimes it automaticly downclocks and details in game gets low and fps drops to about 30 when its about 80 normaly...
Download Afterburner and create a custom fan profile like mine above. You could also frame limit the card to the resolution of your monitor, ie 60Hz = 60fps = less work the card has to do, assuming its drawing more FPS than 60.
Whats your case cooling like, do you have a side panel fan?
thorpas mines was running quite high but that was due to being in an SLi configuration.
About 73C load on a Heaven loop with just one card in the case.
Yours seems a bit high, as suggested get afterburner and see what the GPU usage is like and it tracks the temps too...
Sufficient airflow? What type of case?
My room is pretty warm as well being south facing.
just tried running valley loop for about 3 hours, topped at 70... probably gw2 is really hard on gpu :D will try limiting fps
