Hi,
Would anyone be able to tell me if the 8 Pack Edition is able to utilise the GOC Xoc & tools as I am about to get into Dice and Ln2 overclocking but first want to see what the max I can get on Air/water is (using extreme cold ambients).
Right now I am hitting a wall with Tuner plus as it is the only one that allows for a voltage increase with the HOF above 1.093v but is also a constant voltage and not a progressive which is a nightmare for keeping temps down.
The Xoc removes this issue but would first like to know (if possible) that it will work okay with my 1080Ti.
Thanks in advance.
Thanks in advance.
