KFA2 GeForce RTX 3090 HOF Thermal Pads
9 Mar 2021
Hey Guys
I put together a custom loop awhile ago and put a waterblock on the graphics card. Its been nothing but problems since then with fixing a leak awhile back having to drain it and find the location. Well it seems to be leaking again so i am just fed up with it and want to put it back to a air cooled system.
Is there a source anywhere that would be able to help identify what the thermal pads I need to get to put the air cooler back on?
Cheers
Hey Guys
Cheers
Measure the ones it originally came with. Cooler master pads are super squishy, low shore. Probably get away with 2.0mm, likely a combination on 1.5mm and 2.0mm anyway.
