Just sold my Kickr 1.
Loved it, but the whine from the flywheel especially at higher speeds is a little loud.
Need to buy a replacement.
Neo is quieter, and reacts quicker to gradient changes on zwift as it's magnetic.
Quality maybe not quite as high as Kickr, and has a stupid campag cassette ring even if you run a SRAM or Shimano cassette.
Kickr 2. A little quieter than kickr 1. Best support, maybe better build quality. Comes with a cassette and easy to change.
What do you guys think?
Shane Miller who is THE zwift guy in Aus recommends the kickr over the Neo if they are the same price. Noise maybe less of an issue here.
I used to use mine in the garage (joined to house by one wall) and my wife could hear it in the house.
