Does it actually reduce ping? What if you have a ***** connection, will it help?
So in summary, you're more likely to see a performance increase because the NIC will take over part of the network processing and can run a firewall on its self, again taking away tasks from the cpu. Personally I dont think its worth it as I've never thought to myself that my firewall is taking up too much resource, and as for the network stack....
For the amount it costs, though, you could perform a substantial CPU upgrade, which would increase CPU performance much more than moving networking tasks off the processor!
While that's all true it's primary function is to bypass windows tp stack. Widows being promised for data transmission rather than latency means it queues things up as they go in and out. Sadly this can be done with quite simple windows tweaking for zero cost.
While that's all true it's primary function is to bypass windows TCP stack. Windows being optimised for throughput rather than latency means it queues things up as they go in and out. Fortunately latency optimisation can be done with quite simple windows tweaking for zero cost...
Allow me to translate![]()
