- 16 Feb 2010
- Southend-On-Sea, Essex
I use a killer nic xeon pro. I have had really good experience using it, just wondering if ne one else here uses one?
If you want a better NIC than the standard one built into a motherboard, just get an intel pro/1000 card. Spend the money saved buying that instead of a killer nic and put that money into a new graphics card or CPU and you will get much better results.
if you go :
Start > Run > type "CMD" > Ok
that opens a command line. Simply type :
tracert www.google.co.uk
that will test the connection so to speak to googles server. A before and after will show us much more detail
Thank you.
