Kingdom hearts 2
16 Sep 2005
What used to be a UK
Can the above (American version) play on a Uk Console (PS2) Need 2 know this for my daughter. Thanks.
Tried&Tested said:
Very much doubt it unless you have one of those region changer things. Also, their TV format it NTSC...does her TV support that?
Good question. She only uses a portable so I would say no. Thank you :)
Lots of portables support NTSC.
Does the remote have an AV button ? Is there a scart socket in the back of the TV ?
If yes and yes, it'll do NTSC.... 99.99% I recon.
The TV probably will work (though it depends on the age, having a SCART doesn't necessarily mean anything) - but PS2 games are region protected. The game will refuse to run, unless you've modified your console in some way.
