Hi there
OcUK has some of the "pre-binned" KingPin cards on the way, yes the price is crazy, yes it is totally stunning and should overclock like an absolute crazy thing.
UK allocation is 24 units, OcUK has 12 of those units, this is one time very exclusive edition card:
EVGA GeForce GTX 980Ti KingPin "Pre-binned GPU 72%+ ASIC" 6144MB GDDR5 PCI-Express Graphics Card (06G-P4-4998-KR) @ £799.99 inc VAT
The EVGA GeForce GTX 980 Ti K|NGP|N graphics card is designed for overclocking perfection. With a 14+3 power phase design, this new digitally controlled VRM can deliver up to 600A of current, all delivered through 3 power inputs. ACX 2.0+ cooling keeps the card running cool, and the ability to go single slot, with the included single slot bracket, makes this one of the most versatile graphics cards on the planet. You can get a card customized for you with the new K|NGP|N OC Project.
Virtual Reality is upon us with the likes of Oculus Rift already available and HTC Vive coming very soon. Valve have released a SteamVR benchmark which will test your system for VR Readiness, we advice customers to run this benchmark as the minimum specification to be VR Ready is a GTX 970 from camp NVIDIA. A GeForce 980Ti scores 10-11 in the SteamVR benchmark which is the highest score possible. So if you want the best possible VR performance than GTX 980Ti or Titan X is the answer for truly the best VR gaming experience. VR is a game changer for games such as Elite Dangerous, Portal 3, Flight simulator, Doom, Project cars and who knows the elusive Half Life 3 may make an appearance from Valve as being VR optimised, lets keep our fingers crossed.
Features:
- Virtual Reality Ready
- Great for 4K (GeForce GTX 980 Ti & above)
- DirectX12 Ready
- Gamestream to NVIDIA SHIELD
- Pre-Binned GPU, 72%+ ASIC
- EVGA's 24/7 Technical Support; Base Clock: 1203 MHz / Boost Clock: 1304 MHz
- Memory Clock: 7010 MHz Effective; CUDA Cores: 2816; Memory Detail: 6144MB GDDR5
- Recommended PSU: 600W or greater power supply
Specification
- GeForce 980Ti
- GPU: GeForce 980Ti
- Core Base Clock: 1203MHz
- Core Boost Clock: 1304MHz
- Memory Clock: 7096MHz
- Memory Size: 6144MB GDDR5
- Bus Type: PCI Express 3.0
- Memory Bus: 384-bit
- CUDA Cores: 2816
- DirectX 12: Yes
- DVI Port: 1x Dual-Link DVI, 3x DisplayPort & 1x HDMI
- DisplayPort: Yes
- HDCP: Yes
- HDMI: Yes
- Power: 1x 6-Pin & 2x 8-Pin
- 600W PSU Required
- 250W TDP
- Dimensions: L=282mm, W=110mm, H=43mm
- Warranty: 3yr (Product Registration Required!)
Only £799.99 inc VAT.
ORDER NOW
EVGA GeForce GTX 980Ti Classified 6144MB GDDR5 PCI-Express Graphics Card (06G-P4-4998-KR) @ £569.99 inc VAT
Introducing the EVGA GeForce GTX 980 Ti Classified. Accelerated by the groundbreaking NVIDIA Maxwell architecture, and combined with enthusiast features such as 14+3 Power Phases, Dual BIOS support and more, the EVGA GeForce GTX 980 Ti Classified delievers unmatched overclocking and performance. With 2816 NVIDIA CUDA Cores and 6GB of GDDR5 memory, it has the horsepower to drive whatever comes next. In fact, the EVGA GeForce GTX 980 Ti provides 3x the performance and 3x the memory of previous-generation cards*. You can now take on even the most challenging games at high settings for a smooth, ultra high-definition, 4K experience.
This card also features EVGA ACX 2.0+ cooling technology. EVGA ACX 2.0+ brings new features to the award winning EVGA ACX 2.0 cooling technology. A memory MOSFET Cooling Plate (MMCP) reduces MOSFET temperatures up to 13%, and optimized Straight Heat Pipes (SHP) reduce GPU temperature by an additional 5C. ACX 2.0+ coolers also feature optimized swept fan blades, double ball bearings and an extreme low power motor, delivering more air flow with less power, unlocking additional power for the GPU.
Ti. The most powerful two letters in the world of GPUs. When paired with our flagship gaming GPU–GeForce GTX 980–it gives you incredible new levels of performance and capabilities. GTX 980 Ti is accelerated by the groundbreaking NVIDIA Maxwell™ architecture to deliver an unbeatable 4K and virtual reality experience. With 2816 NVIDIA® CUDA® cores and 6 GB of memory, it has the horsepower to drive whatever comes next.
Get VR Ready with GeForce® GTX.
GeForce® GTX graphics cards provide a powerful next-generation platform for the ultimate immersive virtual reality experience. Immersive VR requires seven times the graphics processing power of traditional 3D apps and games. NVIDIA's unique set of features-such as multi-res shading-mean you get the right level of performance, image quality, and latency to ensure your VR experience is nothing short of amazing.
Features:
- VR Ready
- DirectX 12 Ready
- 4k Ready
- 6144MB VRAM
- Titan X PCB
Specification
- GeForce 980Ti
- Core Base Clock: 1190MHz
- Core Boost Clock: 1291MHz
- Memory Clock: 7010MHz
- CUDA Cores: 2816
- DirectX 12: Yes
- DisplayPort: Yes
- HDCP: Yes
- HDMI: Yes
- Power: 2x 8-Pin
- 600W PSU Required
- 250W TDP
Was [£619.99] Inc. VAT
Only £569.99 inc VAT.
ORDER NOW
Features:
- DirectX12 Ready
Specification
- GeForce 980Ti
- CUDA Cores: 2816
- DirectX 12: Yes
- DisplayPort: Yes
- HDCP: Yes
- HDMI: Yes
- 600W PSU Required
- 250W TDP
ORDER NOW
Features:
- VR Ready
- DirectX 12 Ready
- 4k Ready
- 6144MB VRAM
- Titan X PCB
Specification
- GeForce 980Ti
- CUDA Cores: 2816
- DirectX 12: Yes
- DisplayPort: Yes
- HDCP: Yes
- HDMI: Yes
- Power: 2x 8-Pin
- 600W PSU Required
- 250W TDP
ORDER NOW
