- 19 Mar 2007
Hi all,
Just purchased Kingston 2gb PC 6400 800mhz DDR2 (2x1gb) from a mate for a bargain price was looking at getting A Shuttle XPC SB95P V2 skt 775 lga, currently out of stock at overclockers was just wondering as im pretty new to DDR2 whether it would run on this shuttle as it states:
"Memory Support
- 2 x 240 pin slots, supports Dual Channel supports DDR2-533/400 memory modules at 533/400 MHz up to a total size of 2GB (max. 1GB per DIMM)"
Would it have a reduced effect, as in running at the highest setting of 533 mhz or would it be incompatible??
Cheers
"Memory Support
Cheers
