Go play a game that will bring out any memory instability.Ok so I decided to memtest86 with ram set to expo1 on the mb and it failed on the 1st run almost immediately
So I ran it again and it passed 3x tests fine. Do I need to perform other tests using other software or longer tests with memtest86?
Will Star Citizen do the job ?Go play a game that will bring out any memory instability.
Ok so Star Citizen crashes after playing for 5 mins each time. Should I turn off EXPO completely (If I can?)
However I get these errors now in Star Citizen:
GPU crash message: GPU CRASH (async): [...evice/Legacy/GPUBufferLegacy.cpp:63 CGPUBufferD3D11Legacy::CGPUBufferD3D11Legacy] (0x887A0005) DXGI_ERROR_DEVICE_REMOVED The GPU device instance has been suspended. Check gpu_error.log for more details, raise value of r_gpuMarkers and / or run with r_enable_full_gpu_sync = 2 to get to the source of the problem
I have now enabled full gpu sync via command line in the game and am awaiting the next game crash.
This is what the gpu_error log states from Star Citizen:
GPU status: Aftermath not available on non-NVIDIA GPUs
Pipeline section: Unknown
I guess should I keep going with troubleshooting the Star Citizen crashes with expo disabled until I can get it stable and no GPU errors? (and then go back to expo or manual timings - I dot know what these would be?)
I've messed around with the Adrenaline software and disabled a few things and I managed to play CS for about 3.5 hours last night without it crashing so fingers crossed.Hmm, when I google this error, there seem to be A LOT of posts about the problem and few solutions. One of them mentions that rolling back the drivers helped (to 22.5.1), rather than using the latest.
That would be best I think, yes. For the timings: either get them from CPU-Z (which can read the profiles for you), or google the model number of your RAM + pdf, which will get you the datasheet.
So for the RAM timings should I follow these from the data sheet? Or is it a matter of trial and error?
FACTORY TIMING PARAMETERS
• Default (JEDEC): DDR5-4800 CL40-39-39 @1.1V
• XMP Profile #1: DDR5-6000 CL40-40-40 @1.35V
• XMP Profile #2: DDR5-5600 CL40-40-40 @1.25V
• XMP Profile #3: DDR5-4800 CL38-38-38 @1.1V
thanks very much mateYeah, XMP profile 3 is a waste of time, I doubt you'd see any difference from the JEDEC profile, so I'd start with profile 2.
Hi, Can anyone point in the direction of where the RAM timing settings are located in the BIOS DDR5-5600 CL40-40-40 @1.25V. I cant see anything that relates to timings?
Try TM5 with the anta777 absolut config. and Y cruncher with the VST test. you can find out more about those by Googling. not sure if I can link them hereOk so I decided to memtest86 with ram set to expo1 on the mb and it failed on the 1st run almost immediately
