** KINGSTON GO CRAZY WITH THEIR LOW LATENCY PREDATOR DDR4!! **
OcUK Staff
17 Oct 2002
OcUK HQ
HI there
Kingston have given us some epic support to sell their Predator DDR4 at very low prices, the advantage of the Predator DDR4 kits is they run at very low latencies compared to other kits which helps improve performance:
Kingston Predator 16GB (4x4GB) DDR4 PC4-19200C12 2400MHz Quad Channel Kit - Black (HX424C12PB2K4/16) @ £155.99 inc VAT
Kingston Predator DDR4 is some of the most aggressive looking DDR4 available and looks menacing. Make your opponents fear you with Kingston Predator DDR4.
Specification:-
- CPU Compatibility: Intel Haswell-E ( LGA 2011-3 )
- Chipset: Intel X99
- Capacity: 16GB (4GBx4)
- Quad Channel kit: Yes
- Tested Speed: DDR4-2400 MHz (PC4-19200)
- Tested Latency: 12-13-13-35
- Tested Voltage: 1.20-1.35V
- Registered/Unbuffered: Unbuffered
- Error Checking: Non-ECC
- Type: 288-pin UDIMM
- SPD Speed: 2133 MHz
- SPD Voltage: 1.2V
- Features: Intel XMP 2.0(Extreme Memory Profile)Ready
- Warranty: Lifetime
Was [£179.99] Inc. VAT
Only £155.99 inc VAT.
ORDER NOW
Kingston Predator 16GB (4x4GB) DDR4 PC4-21300C13 2666MHz Quad Channel Kit - Black (HX426C13PB2K4/16) @ £191.99 inc VAT
Specification:-
- Tested Speed: DDR4-2666 MHz (PC4-21300)
- Tested Latency: 13-14-14-35
- Tested Voltage: 1.25-1.35V
- SPD Voltage: 1.2V
Was [£215.99] Inc. VAT
Only £191.99 inc VAT.
ORDER NOW
Kingston Predator 16GB (4x4GB) DDR4 PC4-24000C15 3000MHz Quad Channel Kit - Black (HX430C15PB2K4/16) @ £239.99 inc VAT
Specification:-
- Tested Speed: DDR4-3000 MHz (PC4-24000)
- Tested Latency: 15-16-16-36
- Tested Voltage: 1.25V-1.45V
- SPD Voltage: 1.2V
Was [£249.95] Inc. VAT
Only £239.99 inc VAT.
ORDER NOW
This is some seriously quick DDR4 and is far cheaper than our competitors are selling slower Corsair DDR4 kits for. Well worth jumping on! :)
Silent_Scone have you had a go at tightening up your timings on your DDR4.
For what sorry? Write latency, TFAW and TRRD can come down a notch. I tend not to go too crazy with secondary and terts for 24/7. Most end users timings are wrong anyway.
That pass above is 10 passes on the 3000 kit at 3200 C15-16-16-39 1T.
Just the primary, Latency etc you do not really get a lot of secondary's.
You'll struggle to find kits that will tighten much further down that CAS 15 at 3200 and be unconditionally stable with Memtest pro :) sub 1.45v
CAS 14 and below are achievable with the right voltage, but I don't juice my kits for 24/7. Plus even then stability maybe conditional depending on the memory and the strength of the IMC.
Don't believe everything you see with DDR4, stability is in the eye of the beholder ;)
Yes It looks like the manufactures have hit the limit with the current generation of IC`s
