Quick question,
Quoted from ocuk's shop Recommended memory voltage is 1.50v, so make sure to run your memory at 1.50v, higher than 1.60v could limit lifespan of the CPU Bios is showing voltages as 1.65v if I drop the voltage down to 1.5v I get BSOD.
CPUZ's timing table under SPD tab shows;-
JEDEC #2, JEDEC #3 and JEDEC #4 @1.5v
XMP-1600 @1.65v
What does the above mean? should I be worried?
XMP-1600 @1.65v
