*** Kingston Hyper X RAM Fan ***
Suspended
18 Oct 2002
OcUK HQ
*** Kingston HyperX Cooling Fan (KHX-FAN) @ £15.98 inc VAT ***
Kingston® proudly introduces the HyperX® Fan. Designed with the gamer and PC enthusiast in mind, its dual 60mm fans optimize airflow around the modules to help memory run at peak performance for longer periods of time. The fan is made of anodized aluminum in the same familiar blue color as the HyperX heatspreaders. When turned on, the fan blades are illuminated by eight small blue LEDs. The HyperX Fan is available as a standalone product or bundled with Kingston's 6GB 2000- and 1800MHz triple-channel memory kits with the T1 heatspreaders for Intel Core i7 systems. It's backed by a one-year warranty, 24/7 tech support and legendary Kingston reliability.
Keep your cool - order your HyperX Fan today!
- Whisper-quiet — 28 dBAm maximum
- 12V rated. 8V-13.5V operational range
- RPM: 3000 +/- 10%
Only £15.98 inc VAT
ORDER NOW
Aren't these just a marketing ploy? Since RAM uses less voltage as it gets more advanced and it's more efficient, it's going to give off less heat. If anything needs extra cooling, it's older RAM, and well... it didn't. Why would it now?
To get tighter timings and better stability sometimes you need to pump up the voltage on your RAM, I've got some OCZ stuff I'm putting 2.2v through and the heatspreader actually gets quite hot, not so hot it needs active cooling but still.
I guess they could look good in a nice modded setup.
I usually undervolt everything a little... unless of course i'm trying to increase the speed, but in memory it's pointless, you can't notice a difference between 667 or 800 or 1600MHz.
Also, why is it called Random Access Memory? Surely it should be Logical Access Memory?
