KINGSTON HYPERX 4GB DDR2 8500C5 1066MHZ DUAL CHANNEL KIT ONLY £76.99 INC. VAT
17 Oct 2002
Stoke
We have just knocked off a massive £23.00 off the price of one of the best DDR2 kits on the market.
Kingston HyperX 4GB (2x2GB) DDR2 8500C5 1066MHz Dual Channel (KHX8500D2K2/4G) @ £76.99 inc VAT
HyperX DDR2 modules are specifically engineered and designed to meet the rigorous requirements of PC enthusiasts. HyperX DDR2 offers faster speeds, lower latencies, higher data bandwidths and lower power consumption than DDR.
- Size: 4GB Kit (2x2GB)
- Speed: 1066MHz
- Timing: 5-5-5-15
- Format: 240-Pin DDR2 DIMM
- 2.1 Volts
- Lifetime Warranty
Only £76.99 inc VAT.
ORDER NOW
finally...1066MHz ram that isnt £100+
EDIT: Will this work at full speed in a P5Q Pro turbo?
now if you could only drop the price of this down to the level it was at last year would make it an even better bargan.
i only wish i got 2 sets of it then when it was only £45 a set including VAT.
I also got some of this when it was £38 last year. Problem is that Flash prices are so volitile and all the dimms are getting sucked up for use in SSD and other flash based products.
I thought DDR2 prices would continue to head north whilst DDR3 would head south. Well thats what I hope anyway as its the only thing scuppering my upgrade.
Why is it "so cheap" though, their other ones are still more expensive, must be a manufactuaring error or something?
they are indeed.
can anyone put what timings they got thiers to run at
I got mine past 1066 (can't remember how fast :P) without looking but they are still on CAS 5
