Hi all,
Slight issue with my brother's computer. He's recently purchased 2x2GB of Kingston HyperX 8500 1066MHz DDR2 RAM, for use with his Gigabyte EP45-UD3LR motherboard.
With both modules in, he gets IRQ_NOT_LESS_OR_EQUAL stop errors, but with 1x2GB module in it's fine. He has two identical sets of RAM (so 8GB in total), and both sets cause the same problem.
Any idea what I should check? I've changed DRAM Performance mode in the BIOS from ''Turbo'' to ''Standard'' and will let you know if that changes anything, but at the moment I'm at a loss...
Cheers!
Cheers!
