Kingston HyperX Blu 8GB
Looking at buying 16gb of this memory, is it any good for the price and is there anything else i should be looking at, dont overclock much so not really bothered about that
http://www.overclockers.co.uk/showproduct.php?prodid=MY-098-KS
Nothing wrong with that memory at that price.
What motherboard is it going in and are you running a 64 bit OS?
The only other thing to consider is that for £12 more (16Gb) you could get it's faster older brother (this too should run at ~1.5V)- Kingston HyperX Genesis Grey. But you will need to make sure your MB can run at 1600MHz. (This info is just for comparison - the reality is that there will be very little speed increase...)
