Kingston HyperX Genesis 6GB & Memory_Managment BSOD
25 Sep 2008
Orsett, Essex
Hi recently been getting a BSOD when using a lot of memory intensive games and apps, Run memtest86 and came out with 32 errors and wouldn't continue the test I think not sure as never used it before but stuck my old patriot set in and error has not returned since. So I am thinking that it has failed not sure which stick but cannot be messing about with testing individually when I have other stuff to use till I either get it RMA'd or new set purchased.
I noticed they say lifetime warranty I bought these in Feb last year so need to get hold of Kingston and see what the deal is I'd imagine?
Send RMA requiest to them, you will need to return all 3 sticks (assuming you bought as a triple channel set) and hopefully should return a new set.
I had issues with OCZ ram a few years ago with my i7 920 setup.
