 - 20 Dec 2010
Hello,
I have 2 x 2GB of Mushkin Silverline working perfectly with my Gigabyte ga-h55m-ud2h motherboard with an i3-530.
Recently due to a university project I have to data analyse 100's images at once and I thought a RAM upgrade would help speed up the process of doing it in batches (which is a real pain).
I ordered : Kingston HyperX Blu DDR3 1333MHz CL9 8GB DIMM Memory Module (Kit of 2).
This should be perfectly compatible as it is the same timings, voltage and speed. The mobo takes 4GB modules maximum. I replaced these with the 2 x 2GB modules in the same slots for dual channel operation.
The PC boots up although it will not load windows beyond 'CLASSPNP.SYS'
I even tried a new windows install on another hard disk and the same fault happened.
I am about to return the RAM as it does not work.
Any ideas?
Thanks
Any ideas?
Thanks
 All down to the way it's written.
