Kingwin PSU @ OCUK ?
22 Mar 2012
London
Hopefully this is the correct place for this post. I was interested in buying Kingwin LZW-550 Platinum. Cant find anywhere in UK aside from ebay.
Kingwin has OCUK listed in their distribution/online resellers section
** Please don't link to competitors **
Whats the deal?
That is a completely different company which is listed there, and just to say, I would remove the link, as it is possibly the worst one you could have posted for mentioning competitors :p
My bad, this wasnt how i wanted to start things off. Im aware of the rule but i thought perhaps in this context, it was ok. Wont happen again.
On topic, any plans to stock up on Kingwin LZW-550 Platinum?
h88p://www.techpowerup.com/reviews/Kingwin/LZP-550/
looks nice, but tbh never heard of them, must be a usa company im guessing?
h88p://kingwin.com/contact/index.asp
china and usa then :)
Ive seen a few reviews for that psu and they all seem to come to the same conclusion interms of its stability/efficiency. In the past ive used coolermaster but im looking for a psu that doesnt spin up while idle. Seasonic X range is one example but the company have just released an update of their X series, which is also absent on our shores at time of writing :(
everything comes to those that wait, some day, hopefully, or order from usa, but rma will be costly if it goes pear shape.
or take AtaRo advice, it may happen / work, good luck
