I am about to complete on a new build and there are some very small and niggly issues with the kitchen, I am going to try and get them sorted out by the builder/fitter but I think I may be wasting my breath based on what has happened so far.
What would be the best way of sorting the following issues out
1 - as the kitchen is quite long worktops have had to be joined together, one of the joins is fine, the other isn't quite perfect and bits of the edge of the laminate will come away if not sorted.
Can I use normal black silicone sealant to fill this join in, all I am concerned about here is durability.
2 - Again relating to the length of the kitchen, one of the kick plates is not a great fit and I think this is because it is so long and only has a couple of clips on the back of it, if I push on it in certain places (about the same amount of pressure regular mopping would place on it) the end kind of bows out a little and it no longer sits flush with the other kick plate. So will extra clips hold this in place better or is there an easy way to secure this better ?
3 - the valance around the top of the cupboards has cracked on the corners (I assume the glue wasn't too great) I can glue these and put them back on but the other issue is where they have been cut the laminate has chipped away very slightly on the edge (I assume due to the nature of the finish) which not glaringly obvious I can see it and it does bug me, is there some kind of paint or filler I can use to disguise this ?
4 - The door on the integrated washing machine is ever so slightly out, having never had integrated appliances before I don't know whether this one is normal or not, can these be lined up perfectly ? if so what needs to be done ? (It sits slightly recessed at the bottom of the door)
I am popping down to the house later and will try and get some pics to illustrate what I am talking about
