I am looking to replace my LED tube lights under my kitchen wall units. I was hoping that the set of GOVEE lights I bought(usb connection) would be sufficient, but unfortunately not. They are nowhere near as bright as I need them to
The LED tubes I have at the moment are 284mm which are 5W 360 Lumens. I have 2 linked together on one set of units and the same on another set on the other side of the kitchen. I am looking for replacements which are as bright if not brighter,and ideally which are dimmable. I know I seem to be asking for maybe the impossible at a reasonable price.
I am also looking to replace my kitchen ceiling light to LED, but it needs to be dimmable...either by switch or by remote. I have spent hours looking for something suitable on the likes of Amazon EBay etc but the main issue is that either they are not dimmable or the wattage is not sufficient.
Any advice would be much appreciated
Thank you
Thank you
