Hi all,
My wife wants to get some new kitchen wall cabinets put on the wall which divides the kitchen to the front room as she wants more storage.
I’ve said fine, but she’s also expecting me to put them up, I’ve said I want a pro to put them up but quotes have come back as roughly £200 to put up 2-3 wall cabinets. To her, this is nuts as she thinks it’s a 5 minute job and just screwing in some screws.
So basically I’m asking, just how difficult will this be? I’ve not done hardly any DIY except to put up some shelves by drilling a small hole then using a screwdriver, driving in some wall plugs designed for plasterboard I think which seems to work well.
Firstly I’m concerned about the wall she wants them on, before she’s just wanted a shelf, however this wall seems a lot more sturdier than other walls, as in, I wasn’t able to screw in the above walls plugs with a screwdriver, I’m also concerned with getting it perfectly level and aligned as she will expect this to be perfect. This wall also contains the switches for the 2 lights and extractor fan.
So yeah, how difficult is this likely to be? Tools needed? Any recommendations on units?
Any help would be greatly appreciated.
Thanks in advance.
Thanks in advance.
