I've been away for the last few weeks and not had a chance to work on the build that much. With that said I did receive all the fittings (my god they are expensive) and have started mocking up the configurations using the mobo, cpu and block from my old 2600k build. It turns out that I forgot a few fittings so have ordered the final pieces for the build which I will try to make in roads on next weekend.
The black sparkle fittings are looking great if I do say so myself
With the singularity brackets on the pump the Rad-Pump connection should look pretty good in particular when compared to other builds.
One of the open items I have right now is where to put the temperature sensor. A couple of options are in the pump or using one of the T connections I have spare.
