- 21 Jan 2014
- Fife
Been having some issues with my PC recently. It has been BSODing once or twice a day with the following error. It has been the ntoskrnl.exe and the snakeeyes.exe that has caused this and I'm sure the latter is caused by the Corsair M65. Can anyone shed any light on this or am I best to just do a clean install of Windows 8.1?
Rest of spec is in sig.
Cheers!
On Tue 12/08/2014 14:07:47 GMT your computer crashed
crash dump file: C:\WINDOWS\Minidump\081214-28562-01.dmp
This was probably caused by the following module: ntoskrnl.exe (nt+0x153FA0)
Bugcheck code: 0x1E (0xFFFFFFFFC0000047, 0xFFFFF803D2EE9F0C, 0x0, 0x0)
Error: KMODE_EXCEPTION_NOT_HANDLED
file path: C:\WINDOWS\system32\ntoskrnl.exe
product: Microsoft® Windows® Operating System
company: Microsoft Corporation
description: NT Kernel & System
Bug check description: This indicates that a kernel-mode program generated an exception which the error handler did not catch.
This appears to be a typical software driver bug and is not likely to be caused by a hardware problem.
The crash took place in the Windows kernel. Possibly this problem is caused by another driver that cannot be identified at this time.
Cheers!
