OcUK Staff
- 26 Nov 2014
- Stoke
Available for order today, we have the newest addition to the Citadel range - The Kolink Citadel Glass SE. Built using the well regarded & recieved Citadel Mesh structure, the Citadel Glass SE adds both a glass front panel and a pair of ARGB strips to accent the front panel. There is also a USB3.2 Type-C port on the I/O as standard. The Citadel Glass SE features the same PWM enabled ARGB fans as from the Citadel Mesh RGB, that can be controlled via the supplied remote control, or connected to a compatible motherboard and controlled via software. The left hand side panel is tempered glass and hinged, and there's support for both 280mm radiators at the front, and 240mm radiators at the top. Micro-ATX motherboards are supported, alongside 345mm VGA cards, 190mm CPU coolers and 200mm ATX power supplies. There is even support for 2.5 slot vertical GPU's (riser cable sold separately). Stock is available to order today!
We also have available soon, the Kolink Inspire L1 ARGB and L2 RGB controllers. These are low cost solutions for people who would like to add ARGB/RGB devices to their system. They are SATA powered and come with a 3-Pin 5V/4-Pin 12V connector, alongside Phanteks DRGB/RGB and Corsair ARGB/RGB connectors too. The supplied remote allows over 300 effects and modes including brightness and effect speed adjustments. Both models will be landing in stock within the next week.
Kolink Citadel Glass SE ARGB Micro-ATX Gaming Case - Black @ £72.95 inc VAT
Feature rich Micro-ATX Case from Kolink, 3 x 120mm PWM ARGB LED Fans, Hinged Tempered Glass Side Panel, Glass front Panel with ARGB accents, Dual Radiator Support, Vertical GPU Support, USB3.2 Type-C
Only £72.95 inc VAT.
ORDER NOW
Kolink Inspire L1 3-Pin 5V ARGB Controller - SATA @ £7.99 inc VAT
ARGB Fan Controller from Kolink, Connectors for standard 3-Pin ARGB devices plus Phanteks & Corsair, Over 300 colour settings and modes, SATA Powered, Remote Controlled
Only £7.99 inc VAT.
ORDER NOW
Kolink Inspire L2 4-Pin 12V RGB Controller - SATA @ £7.99 inc VAT
RGB Fan Controller from Kolink, Connectors for standard 4-Pin RGB 12V devices plus Phanteks & Corsair, Over 300 colour settings and modes, SATA Powered, Remote Controlled
Only £7.99 inc VAT.
ORDER NOW
ORDER NOW
Only £7.99 inc VAT.
ORDER NOW
Only £7.99 inc VAT.
ORDER NOW
