** KOLINK CITADEL MESH - NOW IN ATX FLAVOUR **
OcUK Staff
26 Nov 2014
Stoke
Available for order today, we have the new Citadel Mesh ATX. Based on the popular Citadel Mesh Micro-ATX series, the Citadel Mesh ATX takes the same visual design and bumps up the size. This results in a case with some significant hardware support such as E-ATX motherboards, 420mm radiators, 380mm VGA cards, 180mm CPU coolers & 200mm PSU's. There's 4 pre-installed Umbra 120mm ARGB/PWM fans, alongside an Umbra Core ARGB/PWM controller, allowing both remote control and compatible 3-Pin 5V ARGB motherboard support out of the box. As with the other Citadel Mesh models, the entire front panel features mesh ventilation for excellent airflow. The tempered glass side panel has two rear screws to release it, which is both convenient and subtle. There's triple slot vertical GPU support included, with the use of an optional PCI-E riser cable. Watercooling support is great, with up to 420mm support at the front, 360mm support at the top, and 140mm at the rear. There's a full PSU shroud with hexagonal cutouts for ventilation and a side mounted I/O panel which has a USB3.2 Gen2 Type-C Port plus 2 x USB3.0 ports and a USB2.0 port. Cable management is great, with velcro cable anchors, cable routing tubes and rubber cable grommets throughout.
The Citadel Mesh ATX is available to order today and presents a comprehensive suite of features for the pricepoint.
Kolink Citadel Mesh ATX ARGB Midi-Tower Gaming Case - Black @ £109.99 inc VAT
ATX mid-tower chassis, 4 x Kolink Umbra 120mm ARGB/PWM fans, Tempered glass side panel with rear screws, Mesh front panel, Up to 380mm long GPU, Kolink Umbra Core fan controller included
Only £109.99 inc VAT.
ORDER NOW
I like the smaller Citadel Mesh and built a couple of systems recently. Aside from the general increase in dimensions which will allow for more options there is a big positive and a smaller negative.
The positive is there now appears to be proper mounting trays for 2.5" SSDs where other Kolink cases you mount direct to the sheet metal. The negative is the side panel isn't hinged like the smaller case which was a nice feature.
Actually the width also means you can mount the ARGB hub where again other Kolink cases that use it aren't wide enough so you end up stuffing it down in the 3.5" drive area.
If the PCI-E riser cable was included at this price then it would be one of my top go to cases but I realise that not everyone will use it so it will remain an option.
The smaller Citadel Mesh came with a vertical GPU mounting bracket so you only had to buy a riser cable.
Does this case require the triple slot GPU mounting kit or just a riser cable? Is the one listed at OCUK the correct one?
Well it's not true, as it's no where near 8x more expensive, prices Shanghai to Rotterdam aren't even 3x the 5 year moving average price. 40ft is ~$9700 Vs 5 year at ~$3600.
For a start we aren't in Rotterdam. Secondly based on recent container shipping costs, it's approx. 6.7x more cost wise at the moment than it was before they exploded in price. At it's worst it was over 9x more. UK costs involved bump the price up too and they have only increased alongside.
Just the riser cable and yes, that one is compatible.
Really, well blow me down I didn't notice. Rotterdam is the EU central hub for pricing China/EU pricing for containers, the onward UK pricing is irrelevant when doing a comparison vs the moving average 5 year pricing.
So you arrange your own containers, or you buy from the supplier who arranges it? One of the clients I consult for have loads of custom chassis from GUANGHSING, and another vendor - filling a container for own use as opposed to paying a fee on top of the pricing from the vendor. I'd assume since Caseking own OCUK that the stock comes in via Rotterdam on a container just for your group, but maybe you sell less than I imagined of Kolink, but given how many of their PSU's you put in the pre-builds I'd be surprised.
It cost nowhere near $3600 for containers back in late 2020, which is where I am comparing it against. It was more like $2000. Currently it's sitting around $13k. It's absolutely dreadful for brands like Kolink which were focussed on price performance products, but even in this pretty muted market they do well enough to justify the containers coming in and new products being released.
So that is a yes you arrange your own containers then, since you didn't seem to actually answer the question. If not perhaps its time to look for a more competitive freight forwarder.
Don't stop believing that the costs are significantly higher than before. Whether it's sea or air, in fact any way you want it, it's expensive.
