OcUK Staff
- 26 Nov 2014
- Stoke
Available for order today, we have the new Kolink Core RGB 80+ Power Supply units in 500W, 600W and 700W versions. These come with an ARGB side panel featuring serveral modes and effects, which can also be connected to a 3-Pin 5V compatible ARGB motherboard such as Asus Aura. In addition, the cables have been changed to flat black versions. There's also a reusuable alternative design sticker that can be added to the ARGB side plate if you prefer.
Stock is available for order today!
Kolink Core RGB Series 500W 80 Plus Certified RGB Power Supply @ £39.95 inc VAT
80 Plus certified 500 Watt PSU, ARGB side panel, LED effects adjust by built button or standard 3-pin connector, alternate stickers for adjusting RGB design, colourful packaging
Only £39.95 inc VAT.
ORDER NOW
Kolink Core RGB Series 600W 80 Plus Certified RGB Power Supply @ £44.99 inc VAT
80 Plus certified 600 Watt PSU, ARGB side panel, LED effects adjust by built button or standard 3-pin connector, alternate stickers for adjusting RGB design, Flat black cables
Only £44.99 inc VAT.
ORDER NOW
Kolink Core RGB Series 700W 80 Plus Certified RGB Power Supply @ £49.99 inc VAT
80 Plus certified 700 Watt PSU, ARGB side panel, LED effects adjust by built button or standard 3-pin connector, alternate stickers for adjusting RGB design, flat black cables
Only £49.99 inc VAT.
ORDER NOW
ORDER NOW
ORDER NOW
ORDER NOW
