Kolink KLA-002 What case is better for around £45-£50
21 Sep 2008
Was thinking of this case KLA-002 thinking it was a good buy, but then i was thinking once i pay £20 for two fans to go in the front of the case the price rises to at least £45 so no longer a good buy.
So what case can you all recommend around £45-£50
Looking for small Midi Tower Matx case which must have room for 3 3.5inch Drives and one ssd to sit on my Desk also it will be air cooled no water cooling.
Thanks in Advance
To be honest if you are happy with the look of the case and its features i would get some good quality fans for it, you can up your budget to £50 for a case but the fans supplied will still be crap. Stick with what you have and get some decent quiet good airflow fans :)
