Kolink Observatory (Black) all fan replacement - possible??
8 Dec 2020
Hi OC,
I would like to replace all my RGB fans with new RGB fans and controller. So far, I have been unable to find any guides online or videos on youtube on how to do this.
After closer inspection, it seems like this task is impossible given the chassis configuration.
Can OC offer any advice on how I might replace all my fans on my kolink observatory case?
Thanks, David.
Looking at pictures you can access the screws holding the fans in place, so I'd assume you can remove the front panel of the case to swap them. The front panel itself appears to be held on with big plastic lugs so should just be able to pop off.
