Kolink Observatory case mod
19 Oct 2018
Hi all.
I would like to ask if anyone knows any project about modifying Kolink Observatory pc case.
I am thinking about changing the front glass panel with mesh panel. As well I was considering to drill through rivets holding HDD cage to mount something better for HDD. Another HDD cage with better vibration dampening rubber standoffs would be awesome. As well I am planning to buy different RGB fan controller. I've seen on eBay ones where I can control fan speed as well. What you think guys?
I think you’d be better off buying a new case that meets your needs.
I bought Fractal Design Meshify C.
Regarding Kolink Observatory - I was thinking to remove the front glass panel as it is held with 4 screws and install this mesh filter
More work would be needed with HDD bay in basement (PSU shroud). Find one with correct height and drill out the old one. (just drill rivets and should go, drill new holes and rivet new HDD bay)
But I think i would leave this idea as i am happy with my new Fractal case. Great cable management. Great airflow.
