Kolink Observatory IR remote
23 Feb 2019
i just bought this kolink case, everything is just fine, rgb works, i can switch rgb modes from the case, but i cant get the ir remote working.. any suggestions?
Take out the plastic lip between the battery and the remote. Hold the bottom left button for 5 seconds, should sync it.
