OcUK Staff
- 26 Nov 2014
- Stoke
Available in stock today, we have the newest case in the Kolink range - The Phalanx. The Phalanx is a premium midi tower case with a host of neat features such as an anodised black aluminium front panel with a mesh cutout, ensuring both a classic aesthetic without compromising on the airflow, a toolless hinged tempered glass side panel for easy access, 4 Rainbow addressable dual ring RGB fans with remote control, reset switch I/O and motherboard control (including Asus Aura Sync) along with much more.
Component support is pretty good, with support for 280mm radiators at the top, and 240mm radiators at the front. 370mm VGA cards are supported, along with 160mm CPU coolers. 240mm ATX power supplies can be installed under the compartmented PSU shroud, along with 2 x 2.5"/3.5" drive bays and a further 2 x 2.5" drive mounts. Motherboards up to E-ATX can be installed. Cable management is worth noting, with ample space for cable routing and management. The fan controller hub is magnetic and can be placed wherever it suits you best. Magnetic dust filters can be found at the top, bottom and front of the case.
Kolink have taken feedback from their previous designs and improved in almost every area as far as I can see. The case itself looks really nice, and the features Kolink have added are ideal for the ever changing market. Stock is available today, and I believe it's priced very well considering what's available.
Kolink Phalanx Midi Tower RGB Gaming Case - Black @ £79.99 inc VAT
Stylish Midi-Tower for motherboards up to E-ATX, Tempered glass side panel with hinges, 4x 120 mm dRGB fans pre-installed, Digitally addressable lighting controller/fan hub, Radiators up to 280 mm
Only £79.99 inc VAT.
ORDER NOW
ORDER NOW
