** KOLINK REFINE & ETHEREAL - STAY CLASSY **
OcUK Staff
26 Nov 2014
Stoke
Available in stock today, we have the brand new Refine & Ethereal cases from Kolink. These cases are aimed at those who want both a less gamer-ish front panel, but still want the RGB :) To begin with, the Refine has a gunmetal grey brushed aluminium front panel, with an ARGB strip glowing from the left side of the side venting, which can be controlled by both the front panel I/O and a 3-Pin ARGB 5V connector to the motherboard. The tempered glass side panel is hinged for ease of use and removal. On the I/O panel there is a USB3.1 Type-C port, a first for Kolink, along with a USB3.0 port and 2 x USB2.0 ports. There's space for up to a 280mm radiator at the front and 120mm at the rear. Up to 380mm VGA cards, 160mm CPU coolers and 200mm PSU's can be installed, and there's sufficient room behind the motherboard for cable routing too. There's a 120mm fan pre-installed at the rear. Up to E-ATX motherboards can be installed, along with 2 x 2.5"/3.5" plus an additional 2 x 2.5" drives.
The Ethereal features a different front panel, still with the ARGB, but as a strip on the front panel, next to the side venting. Other than the look of the front panel, it's essentially got the same features as the Refine, including the USB3.1 Type-C, motherboard control for the ARGB strip and hinged tempered glass side panel.
Both the Refine & Ethereal are in stock and available now. Really like the look of these cases to be honest!
Kolink Refine RGB Midi Tower Case - Gunmetal Grey @ £69.95 inc VAT
Stylish Midi-Tower from Kolink with integrated ARGB-LED strip, Brushed aluminium front, Supports motherboards up to E-ATX, Pre-installed 120mm fan, USB3.1 Type-C included
Only £69.95 inc VAT.
ORDER NOW
Kolink Ethereal RGB Midi Tower Case - Black @ £62.99 inc VAT
Stylish Midi-Tower from Kolink with integrated ARGB-LED strip, Supports motherboards up to E-ATX, Pre-installed 120mm fan, Includes RGB controller and controls on I/O panel, USB3.1 Type-C included
Only £62.99 inc VAT.
ORDER NOW
