kolink rocket complex - £20...
You sure it will fit 370mm length? Indeed 2.8 slot support, but even 330mm looks tight based on pics with some 120mm fans in the case.
Looks like a nice case to sit by the TV though, I often think about doing a tiny build with external radiator.
Full discloser i didn't measure the case i will do tomorrow.
the nitro+ is 330 there was loads of room left, this is a photo of the case with a RX 6800 fitted so 27cm card.
so i went and checked it, im going to say 350mm is a good fit
the only thing is it as 2 pcie slots so as long as the card doesn't have 3 slot plate it would fit a massive card. my true 3 slot card had room for more
تصویر
in this case im using a low profile air cooler and the case fans sit next to it.
would i be best with the case fans as intake and the air cooler blowing down, or flittle them and having the air cooling pulling and the card fans exhausting
