OcUK Staff
- 26 Nov 2014
- Stoke
Available for preorder today is the newest iteration in the Kolink Rocket series - The Complex. With a square tower aesthetic reminiscent of the Xbox Series X, the Rocket Complex comprises of 3 aluminium panels with hexagonal cutouts, alongside a tempered glass side panel. This provides an imposing and attractive aesthetic and the gunmetal grey finish fits in nicely with the Rocket styling. The Complex sits at 20.4L volume, and despite this relatively compact size, can support 330mm 2.8 Slot VGA cards, which is connected via a PCIe x4.0 riser cable, the first Kolink case to come with this as standard. Motherboard support is the expect Mini-ITX, with SFX or SFX-L PSU support, space for a 240mm AIO or a 110mm CPU cooler and two pre-installed Kolink Classic 120mm PWM fans. There's a USB3.2 Type-C and a USB3.0 port on the top I/O for fast connectivity.
A nice feature of the Rocket Complex is the amount of screws used instead of rivets, allowing to really strip back the chassis for easy building. The aluminium panels help with passive heat transfer, and the hexagonal cutouts further help with airflow into the case. Stock is due in the next week or so, so preorder now!
Kolink Rocket Complex Aluminium Mini-ITX Tower Case - Gunmetal Grey @ £154.99 inc VAT
Mini-ITX case, Tower-style design, Hexagonal cut-outs, Aluminium and steel chassis, 3mm tempered glass panel, GPU up to 330mm long, 20.4L capacity
Only £154.99 inc VAT.
ORDER NOW
ORDER NOW
