- 3 Feb 2011
So I have a Kolink Rocket lying around, was looking to re-use the case and build another PC with the spare parts I have lying around, but the button doesn't work, the cable have broken off, looks like I have 2 options for this, 1) re-solder the cable to the button, or 2) find a replacement/alternative button and use it, but I can't seem to find specs on this, I'm not sure if it's 12mm or 16mm, or something else entirely, I don't have access to the case right now I can't check.
Option 2) would be the preferred option, that way I can find a button with different LED colors, perhaps even one that's aura compatible.
