Kolink Satellite Micro-ATX Cube Case
10 Apr 2015
Hungerford, UK, Earth
Whilst I had this PC apart, thought I would take a photo to show that this case will only take the smallest of MATX boards, inside the case is a MATX BIOSTAR a68 FM2 BOARD, outside is a ASUS MATX workstation board. As you can see this board would be halfway through the PSU. I have now installed an H110 motherboard since this photo was taken. and I had to use an SFX PSU becuaseit was so tight you couldn't plug the ATX power into the motherboard. basically you cant use any motherboard that extends further than the second mounting holes
Does clearly state what size M-ATX boards fit in the Satellite in 4 separate locations on the description...
yes it does, but most people just read MATX and don't know there are different board sizes. I wasn't planning to use that motherboard in the case but just thought the image might be handy to get a visual reference. I would guess that most coffelake boards and ryzen b450 boards wont fit.
Most likely, but if someone buys a product without at least having a quick read of the description in general then they are bound to have compatibility issues, not just on this case.
