Kolink Satellite Plus any tolerances ?
22 Jan 2018
Hello to everybody...
I am thinking of buying Kolink Satellite Plus (cube) but there is too much restrictions especially when it comes to its Mb with...i am finding plenty of MotherBoards with H : 22.6cm but the width is almost always bigger than 18cm...
I have found couple of motherboards with width around 18.3 - 18.5 cm so i wanted to ask if there is any tolerance in order to fit the mobo....i am willing to do any "soft" mods like turning the PSU facing inwards or something else...
I must say that this case is probably the biggest design fault i have seen in cases....with only a few mm both in height and depth it could accommodate a lot more motherboards and could make a killing an an HTPC / console replacement ....
you need those very small MATX boards, its almost adivisable to use ITX, its all very tight, and PSU cables can foul the the GPU I had to change to a shorter one to fit it in,
Well i was afraid that this was the case....too bad i have left my old job (metal industry) ....i could make a nice clean cut side to side and put a 2-3 cm metal stripe to connect the parts....voila....problem resolved.....
Hey Kolink you are loosing a lot of money here.....for a few mm...
