** KOLINK STRONGHOLD & OBSERVATORY - TEMPERED GLASS AND RGB ON A BUDGET **
OcUK Staff
26 Nov 2014
Stoke
Now available for preorder, we have the Kolink Stronghold and Observatory. These cases aim to offer currently desirable features at a competitive pricepoint. First up we have the Stronghold, which has a brushed aluminium effect front panel, along with a 4mm tempered glass side panel. Added to that it boasts a full PSU shroud, a pair of 120mm fans, 240mm radiators at the front/top, support for up to 380mm VGA cards, 200mm PSU's and 160mm CPU coolers. Considering theres up to E-ATX support (Width 279mm max) and space for 6 fans, I'd say the Stronghold is pretty good value at £35.99!
For those who need their RGB fix, the Observatory has you covered. With no less than 4 RGB Ring fans installed as standard, the Observatory also sports a tempered glass front panel to accentuate the glorious RGB goodness. The fans themselves sport 16 individually addressable RGB LED's per fan, meaning that along with the supplied RGB controller and remote, you can choose from over 300 dynamic lighting effects, both in flowing or solid colour options. You can even add another 2 RGB fans and RGB strips to the controller if you feel that way inclined to create an overwhelming rainbow behemoth! The structure is the same one used on the Stronghold otherwise, so all the comprehensive support from that case is present here too!
I have to say that both these cases represent great value for money, and I look forward to seeing the reviews on both. Stock will be available next week, approx the 8th. We expect these to be popular, so if you want some of this tasty Kolink action, you need to preorder.
Kolink Stronghold Midi Tower Gaming Case - Black Tempered Glass Side Window @ £35.99 inc VAT
Stylish Midi-Tower for motherboards up to E-ATX, Tempered Glass side panel, 2x 120mm fans pre-installed, Radiators up to 240 mm, 2x 3,5/2,5"-slots, Removable dust filters
Only £35.99 inc VAT.
ORDER NOW
Kolink Observatory Midi Tower RGB Gaming Case - Black Tempered Glass Window @ £62.99 inc VAT
Stylish Midi-Tower for motherboards up to E-ATX, Tempered glass side window, Tempered glass front, 4x 120mm RGB fans pre-installed, Radiators up to 240 mm, 2x 3,5/2,5" slots, Removable dust filters
Only £62.99 inc VAT.
ORDER NOW
They look great for the money.. They do look like they are built in the same factory as the Corsair cases.. ;)
..and antecs, anidees, fractal, thermaltat
good value though, whats with the molex on the fans though, i thought these had been ditched years ago
Well i bought one of the cheap Kolink Santuary cases recently and it was pretty good. Some bits were shoddy but it was cheap and i have spares like better standoffs as the standard ones are made from cheese!
I bought a cheap Kolink case recently for a home server as it had 8 disk drive bays.
My only gripe was that it only came with 2 drive caddy's.
As DPD decided to crush it and OC sent me another this didn't turn out to be a problem :D
I was quite impressed with the quality for £35.
Close to ordering the Stronghold as i'm still using the Antec P160 from a decade back :eek:. Observatory is good but im not a fan of such garish RGB
